01 HONDA ELITE S
MIKEBB
01 HONDA ELITE S
Post by MIKEBB »
New to this place and scooter world. I purchase 01 honda elite s and started modifying it. Installed polini corsa and keli hi-speed pulley, drilled the exhaust pipe to the max. I did the break in process and then my carb started leaking gas. I clean and adjust the carb and after I put everything back together the scooter has no take off power. I used to go up hill about 25mph now it won't even go pass 10 mph. Thingking of getting new gears but don't know what kind? please help
happyman
Re: 01 HONDA ELITE S
Post by happyman »
what are you running for a carb??????and where is leaking from what kind of breaking process did you you also. you will need gears with that build to get out iof it what you paid for there is no doubt. i run 8;44.1 gears and i like them. there are a FEW really qualified people on this forum that will prolly chime in.
MIKEBB wrote:New to this place and scooter world. I purchase 01 honda elite s and started modifying it. Installed polini corsa and keli hi-speed pulley, drilled the exhaust pipe to the max. I did the break in process and then my carb started leaking gas. I clean and adjust the carb and after I put everything back together the scooter has no take off power. I used to go up hill about 25mph now it won't even go pass 10 mph. Thingking of getting new gears but don't know what kind? please help
mopedman
Post by mopedman »
you need to run a after market carb on it, it will run like 10 times better, i would go with 8.44 to 1 gears or 7 to one
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
happyman
Post by happyman »
hey mopedman, what rollers would you run with a 7;0 gear??
mopedman wrote:you need to run a after market carb on it, it will run like 10 times better, i would go with 8.44 to 1 gears or 7 to one
mopedman
Post by mopedman »
rollers are very odd, u just need to play with it, i have tryed like 30 different combinations
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
happyman
Post by happyman »
ahhhhhhhhhhhhhhhhh yes they are odd. i have messed around a lot over the last couple years with differant weights and springs myself. its a lot of switching many differant parts in the transmission to get the comebo that is right for each build
mopedman wrote:rollers are very odd, u just need to play with it, i have tryed like 30 different combinations
mopedman
Post by mopedman »
right now in my bike im running 3 8grams and 3 12 grams and it is amazing
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
MIKEBB
Post by MIKEBB »
RUNNING ON STOCK CARB AND EXHAUST. TALKED TO KEONI OF VTCYCLES YESTERDAY AND SAID TO GET CLUTCH SPRING AND COMPRESSION SPRING BUT THEY'RE CURRENTLY OUT OF STOCK. I ALSO ASK HIM ABOUT WHAT KIND OF CARB TO GET AND EXHAUST BUT THEY ALSO OUT OF STOCK. IS THERE ANY OTHER PLACE TO GET PARTS BESIDES VT CYCLE IN HAWAII. I LIVE IN VA
MIKEBB
Post by MIKEBB »
The gas was leaking from carb. The float valve got stuck to open position. I was able to figure it out and clean it. Still running slow on the take off.
The break in process wa to run 300 miles not pass 30mph.
mopedman
Post by mopedman »
you can get them on ebay, put in honda dio and they come up
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
Post by Kenny_McCormic »
MIKEBB wrote:RUNNING ON STOCK CARB AND EXHAUST. TALKED TO KEONI OF VTCYCLES YESTERDAY AND SAID TO GET CLUTCH SPRING AND COMPRESSION SPRING BUT THEY'RE CURRENTLY OUT OF STOCK. I ALSO ASK HIM ABOUT WHAT KIND OF CARB TO GET AND EXHAUST BUT THEY ALSO OUT OF STOCK. IS THERE ANY OTHER PLACE TO GET PARTS BESIDES VT CYCLE IN HAWAII. I LIVE IN VA
I LIVE IN MI, BUT AROUND HERE YELLING IS A BIT OUT OF THE ORDINARY.
MIKEBB
Post by MIKEBB »
What kind of exhaust and carb you guys recommend? Anybody selling used parts?
maddog
Post by maddog »
You never drill out the exhaust just grind the washer out, also never put in a bore kit unless you change the gears and do other stuff, you dial in the trans according to your weight & riding style.
MIKEBB
Post by MIKEBB »
Alright felas, got a new project here.
1. new exhaust manifold - installed, done
2. oko 28mm carb & cable - done, what do I do with bystander cable?
3. 7 to 1 gears, how do I remove the gears with out a press.
4. compression spring, any suggestion how to remove the spring.
5 new exhaust. pg long
