how do you clean a Honda Spree Fuel Pump
- Goped
i am wondering if there is any way to clean a fuel pump and if there isnt where can i buy one?
- Goped
- Goped
If it flows fuel when you suck on the bottom hose its fine. There is a big screen inside the gas tank that keeps the crap out, internals are delicate(dont blow it with compressed air, you will break it) and you cant disassemble it.
Is it really that delicate? If so, I think I need to order a new petcock for my Elite...Kenny_McCormic wrote:If it flows fuel when you suck on the bottom hose its fine. There is a big screen inside the gas tank that keeps the crap out, internals are delicate(dont blow it with compressed air, you will break it) and you cant disassemble it.
- justinnielsen01
- justinnielsen01
Yes, it's really that "delicate," though I wouldn't call using 60PSI compressed air to clean something a "delicate" procedure, esp. on something with a rubber diaphram.Scalpel wrote:Is it really that delicate? If so, I think I need to order a new petcock for my Elite...Kenny_McCormic wrote:If it flows fuel when you suck on the bottom hose its fine. There is a big screen inside the gas tank that keeps the crap out, internals are delicate(dont blow it with compressed air, you will break it) and you cant disassemble it.
Several members have trashed their petcocks doing this. Proper way to clean is to soak in clean gas for a day or two. You can check petcock operation by pulling vacuum on the lower line and checking for fuel flow on the upper line.
If you trash it, gas will leak from the lower line. You can cap it and keep using it, or buy a new one.
Admin, Hondaspree.net
- Goped
Or email Greg at uspmale@yahoo.com
