stalling at idle
BBspree
stalling at idle
Post by BBspree »
My 85 spree has been stalling a bit. It will stall right after start up. and also stall occasionally when I stop at intersections or stop signs after extended amounts of driving.
Could adjusting the carb help?
Cubey
Re: stalling at idle
Post by Cubey »
BBspree wrote:Could adjusting the carb help?
At minimum you could try turning in the throttle screw (called "idle" by some) 1/4 to 1/2 turn and see if it does any better assuming it doesn't try to take off with that screw setting. Do the adjustment when it's up on the center stand to see if the wheel begins to turn when you turn the throttle screw in by 1/4 turn after about 10-15 seconds.
If you haven't cleaned the carb, you should also do that.
1985 Honda Gyro S (project bike, work in progress!)
1984 Honda Spree - Bought May 30, 2008 with 810.8 miles on it. (Sold with ~1600mi)
Others owned/rode/sold: '86 Helix trike, '07 Vino 125, '88 Elite 250
Dac wrote:Friends+your moped=BAD IDEA.
Keoni
Post by Keoni »
The carb clean is good advice but also change your spark plug and clean your electrical contacts for the coil just to be safe.
VTCycles.com for performance parts.
BBspree
Post by BBspree »
ok, where are my spark plug and coil located?
BBspree
Post by BBspree »
ok I adjusted the carb and cleaned off some oil that was on the coil and now it won't turnover. I have no idea what happened..?
Post by Kenny_McCormic »
Define turn over, I hate those words, please use "crank over" and "fire".
BBspree
Post by BBspree »
ok. it tries to start but the engine doesn't kick in. there is noise, it's not a clicking noise so i don't think it's the starter.
does that make since?
hondaman
Post by hondaman »
Put in a new spark plug, make sure plug wire is on tight to plug, and charge your battery.
Maybe you hooked up the coil backwards?
BBspree
Post by BBspree »
i didn't remove the coil I just cleaned it off a bit.
Check for spark?
BBspree
Post by BBspree »
I tried it this morning and it started. So I'm quite confused
Its a spree, they run on luck and hope, if you are confident it will start it will either start or not start to * you off.
