BBspree
Posts: 26 Joined: Wed Jun 11, 2008 11:25 am
Post
by BBspree » Fri Jun 27, 2008 8:46 pm
My 85 spree has been stalling a bit. It will stall right after start up. and also stall occasionally when I stop at intersections or stop signs after extended amounts of driving.
Could adjusting the carb help?
Cubey
Posts: 217 Joined: Thu May 29, 2008 12:32 am
Post
by Cubey » Fri Jun 27, 2008 9:02 pm
BBspree wrote: Could adjusting the carb help?
At minimum you could try turning in the throttle screw (called "idle" by some) 1/4 to 1/2 turn and see if it does any better assuming it doesn't try to take off with that screw setting. Do the adjustment when it's up on the center stand to see if the wheel begins to turn when you turn the throttle screw in by 1/4 turn after about 10-15 seconds.
If you haven't cleaned the carb, you should also do that.
1985 Honda Gyro S (project bike, work in progress!)
1984 Honda Spree - Bought May 30, 2008 with 810.8 miles on it. (Sold with ~1600mi)
Others owned/rode/sold: '86 Helix trike, '07 Vino 125, '88 Elite 250
Dac wrote: Friends+your moped=BAD IDEA.
Keoni
Posts: 66 Joined: Sat Jun 07, 2008 10:19 pm
Post
by Keoni » Fri Jun 27, 2008 10:27 pm
The carb clean is good advice but also change your spark plug and clean your electrical contacts for the coil just to be safe.
BBspree
Post
by BBspree » Sat Jun 28, 2008 9:53 am
ok, where are my spark plug and coil located?
BBspree
Post
by BBspree » Sat Jun 28, 2008 2:27 pm
ok I adjusted the carb and cleaned off some oil that was on the coil and now it won't turnover. I have no idea what happened..?
Posts: 4957 Joined: Sun Apr 16, 2006 11:51 am
Post
by Kenny_McCormic » Sat Jun 28, 2008 2:36 pm
Define turn over, I hate those words, please use "crank over" and "fire".
BBspree
Post
by BBspree » Sat Jun 28, 2008 4:20 pm
ok. it tries to start but the engine doesn't kick in. there is noise, it's not a clicking noise so i don't think it's the starter.
does that make since?
hondaman
Posts: 529 Joined: Mon Jul 23, 1973 10:24 am
Post
by hondaman » Sat Jun 28, 2008 4:27 pm
Put in a new spark plug, make sure plug wire is on tight to plug, and charge your battery.
Post
by Kenny_McCormic » Sat Jun 28, 2008 4:50 pm
Maybe you hooked up the coil backwards?
BBspree
Post
by BBspree » Sat Jun 28, 2008 11:30 pm
i didn't remove the coil I just cleaned it off a bit.
Post
by Kenny_McCormic » Sun Jun 29, 2008 12:49 pm
Check for spark?
BBspree
Post
by BBspree » Sun Jun 29, 2008 5:37 pm
I tried it this morning and it started. So I'm quite confused
Post
by Kenny_McCormic » Sun Jun 29, 2008 9:56 pm
Its a spree, they run on luck and hope, if you are confident it will start it will either start or not start to * you off.
