Few Questions. Spree.
CarrotTop
Post by CarrotTop »
Ok i try searching but it brings way to many threads up to look there for the info i need.
1. Is drilling the holes in the Muffler on a spree going to help at all?
2. port the intake manifold what should i be doing in there. I just dont wanna mess it up haha.
Anyone got like pics of that being done.
3. What other things could i do that are somewhat easy to get more speed outta my spree.
On flats i get 30-33.
Id also like a little quick Acceleration if possible.
Re: Few Questions. Spree.
Post by Kenny_McCormic »
CarrotTop wrote:Ok i try searching but it brings way to many threads up to look there for the info i need.
1. Is drilling the holes in the Muffler on a spree going to help at all? Helps, drill 2 restritions by putting the bit inside the pipe through the tip.
2. port the intake manifold what should i be doing in there. I just dont wanna mess it up haha. take it off, you will see it was not made to flow well, change that.
3. What other things could i do that are somewhat easy to get more speed outta my spree. nothing else easy for accel.
CarrotTop
Post by CarrotTop »
Ok i drilled one hole. To test and see what sounds like.. Louder and seems to have slowed me down some :/ More running and driving to test tomor.
Weird, could be coincidental, do a plug chop.
Riot
Post by Riot »
Plug chop?
Run it wide open for a mile (preferably a mile before your driveway) and kill the motor with it still at wide open hold it open till its dead. Pull out the sparkplug, color of the carbon burnt onto the little ceramic insulator inside the plug tells you if its rich/lean. Coco brown is the perfect color.
CarrotTop
Post by CarrotTop »
It's Coco brown.
Maybe it needs the 2 holes and the 1 hole i drilled didn't create the correct pressure or something? Only did one 2 test.
try 2
jacoby0419
Post by jacoby0419 »
What size should the holes in the muffler be?
Biggest you can fit in there.
CarrotTop
Post by CarrotTop »
Well my spree muffler only has on plate there. So i think it lost some of its compression. I stuck a metal thing up the muffler and didn't hit anything else..
So guess time to do some other mods inside the engine now.
You lost some backpressure, not compression.
evilone
Post by evilone »
I spent $90 for high-po cycle shop to port and polish intake, port exhaust port on cylinder, and shave head. At least I know it's right and I didn't screw anything up. The shaved head was a used one they had, it costed $0. By the time you buy a dremel and bits it would in my opinion be better to take to a performance cycle shop. They know what they're doing.
evilone
Post by evilone »
Previous post is about my 87 elite by the way. I did all the mods to my 85 spree which is now gone, all I got was better take off.
CarrotTop
Post by CarrotTop »
Kenny_McCormic wrote:You lost some backpressure, not compression.
Oops my bad i shoulda been using that word.. :oops:
