What is your top MPH?
DorkoElite303
I hope I posted this in the right thread, but
What is your top speed/MPH? What is your make and model and what set-up are you running?
Down hill? Up Hill?
Down hill? Up Hill?
DorkoElite303
Mines was 110 KPH or 68 MPH on flats and up hill about 70 KPH or 43 MPH. Being I weigh 280lbs. 72cc Polini Corsa, Ported and polished block, 28 OKO carb 140 main 48 pilot, 8-4.1 gearing, ZX Trans, Daytona White center spring and yellow Polini clutch springs running Kitaco light weight clutch, Scorpion X-Factor exhaust.
- burnt_toast
my god, get some gears!DorkoElite303 wrote:Opps Sorry....forgot to do mine.
98 Honda Elite SR
85cc, pully, 28mm carb, light fly wheel, blue center spring, yellow clutch springs, 135jet, 55 pilot jet, CDI, no gears.
49mph flat, 51pmh down hill, and about 43 up hill <---GPS reading
like 7:1.
your top speed will jump up amazing.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
1998 Elite..9.1 gears, highspeed pully..9g rollers..2 baffles pounded out(yes pounded..didn't have a long enough drill bit) everything else is stock.. average 45-48 mph..highest 53-55mph(wind at my back on a flat road)
Honda Elite SA50-S
Stock motor, 9:1 gears, Kelli High speed pulley=a top speed of ?? Maxed the speedo out if that counts..average 45 mph
average 85 mpg
average 85 mpg
DorkoElite303
I Know I know....I was suppose to get a brand new gasket for the gear cover. But they ran out. I got the 7.5 to 1 gear. I've had it as long as I had the Elite....but just to lazy to find a bench press. NOw that I have a press, I don't have a replacement gasket for the gear cover.Dac wrote:my god, get some gears!DorkoElite303 wrote:Opps Sorry....forgot to do mine.
98 Honda Elite SR
like 7:1.
