1994 Elite SR. Complete rebuild help?
check the first message on there. i was on it. actually im on about half of what hes selling haha.Dac wrote:http://www.hondaspree.net/phpBB2/viewtopic.php?t=6039
or you could pick up this cheap stock crank.
but let me know how that pulley works out for you. which one did you get from them?
well i decided to grab the intake mani to see about any porting options, and i realized that the reeds (?) are pretty much stuck to it. I ended up cracking the corner of the plastic base off.
question:
will it not run right now like this?
or
should i just leave this alone and rebuild it stock with this reed, and then when i get the big bore kit + 28mm carb get a new reed (or i have to get a new mani to fit the new carb...?)
thanks guys
question:
or
thanks guys
94 Elite SR.
PoliniCorsa+PGlong+28oko+8.44.1+KeliVariator+HiEnergyCoil+Pirrelis
=fast
=fast
Wont run like that, you need a mani and reeds for the new carb. Call up VT and tell em what you have to spend/what you want to do, they should be able to get you a nice setup.
- burnt_toast
You know I have this piece too right?cf_z wrote:dammnnnn. so you mean i cant even run with this one on the stock piston/setup for a week or two?
Extra $10 and I can throw it in with the other parts, LMK
And yes for stock application it wont seal right and you would have a small leak by that bolt hole.
projects galore
ohh just give it to me for free
i already bought your entire parts supply
but really, i dont know anything about this whole reed system. but sure i'll take it off your hands i guess.
then ide just break the old one off?
94 Elite SR.
=fast
=fast
- burnt_toast
can't do free man, you're already getting the crank and bore super cheapcf_z wrote:ohh just give it to me for free
2stroke explained with reedvalve:
http://www.southernskies.net/page_info/ ... ngine.html
in a nutshell, reeds open and close rapidly to let a/f mix enter the cyl
projects galore
- burnt_toast
planning on it.burnt_toast wrote: wow thats a bummer, why not order from VT? see what kind of deals they got on pipes
Are their shipping charges alot?
i was planning on ordering a variator/carburator/intake from them once i figured out what i needed.
i guess i might just go ahead and order an exhaust and variator now, and carb and intake on another order.
94 Elite SR.
=fast
=fast
