Throttle Sticking open on Spree
jacoby0419
Post by jacoby0419 »
I have an 84 spree that the throttle will occasionally stick open on. I am wondering what I can do to prevent this. I replaced the throttle cable- my old one was hard stuck and wouldn't adjust. Can I replace the spring in the carb end of the cable with a stiffer one?
RideRed1
Post by RideRed1 »
Check your slide in the carb, pull the cap off and see if you can get it to move freely, might be binding or needle not seating correctly
2 1984 honda sprees
