Better take off.
MIKEBB
Better take off.
Post by MIKEBB »
I want a better take off speed. How do you do it?
Set up: Polini corsa, 28 mm oko carb, up graded intake manifold, pg long, 1500 rpm spring, polini clutch spring, 7:1 gear, racing cdi.
I have no problem with top speed. I would rather have better take off than top speed. I feel like I have to open the full throttle just to get the scooter to start moving.
Post by Kenny_McCormic »
Stiffer clutch springs or 8.44 gears.
What about getting lighter weights?
MIKEBB
Post by MIKEBB »
I did install polini clutch spring.
I did install hi speed pulley from vt cycle. don't know about the weights.
what weight would you recommend?
Dac
Post by Dac »
well, i talked to a few people and the PGLong pipe that everyone runs is not the best for take off. The pgLong is really a 90cc pipe, it works great for giving 72cc bikes the best top end, but you would get tons more take off with a 72cc based pipe.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
That might work.
