1993 honda elite sr 50
losthope
Post by losthope »
did this bike come from the factory restricted? can anyone tell me before i risk snaping the exaust bolts off to check... also should it have the plate restricter behind the front clutch? the bike already goes 33-35mph with no air box(didnt come with the scoot) so id be stoked if it was restricted thanks for your time
Dac
Post by Dac »
bad news dude, no such thing.
that bikes top speed is only 35mph. There is no restickers or anything.
I would highly recomend getting a UNI air filter for it though. I had a 92 elite SR, i got a UNI filter from a local performance shop and it helped out quiet a bit. And it filtered out dirt and other harmful things to the motor.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
Post by Kenny_McCormic »
Put a filter on it and do a plug chop before you wear it out/melt it!
losthope
Post by losthope »
Kenny_McCormic wrote:Put a filter on it and do a plug chop before you wear it out/melt it!
whats a plug chop?
Dac
Post by Dac »
put a new plug in, run for a few miles wide open. kill the motor at top speed, let the motor cool, remove plug and look at the color.
White-lean (very bad)
co-co brown- perfect.
dark, black, wet= rich (kinda bad)
with no filter you will run lean, running lean your motor will over heat and seize up.
losthope
Post by losthope »
Dac wrote:put a new plug in, run for a few miles wide open. kill the motor at top speed, let the motor cool, remove plug and look at the color.
got cha, just never herd it called a plug chop before... where can i get a new main jet for my carb? will the dealer have them? or will i have to mail order? thanks
Dac
Post by Dac »
yeah, honda should have them.
But dont run it without a filter.
Elite1998
Post by Elite1998 »
Get a filter on it!
Not only are you leaning out the motor but your getting a bunch of crap where it doesn't need to be
Honda Elite SA50-S
Stock motor, 9:1 gears, Kelli High speed pulley=a top speed of ?? Maxed the speedo out if that counts..average 45 mph
average 85 mpg
