1987 Elite 50s rough acceleration
jeepvolks
Post by jeepvolks »
I've only had this machine since Saturday and I've almost brought it back from certain death. Anyway, it starts instantly and idles great. It also runs great at top speed around 35mph. When you start off from a dead stop or from a slow rolling speed, it stutters and bogs and then finally takes off and rips. I've replaced the plug, air filter, disassembled and soaked the carb in carb cleaner. Put everything back together and not much difference. What else could it be?
Thanks for your suggestions in advance.
Andy
1983 Aero 80
1984 Gyro
1987 Elite 80
1993 Elite 80
Post by Kenny_McCormic »
Plug chop
GIJoeBob
Post by GIJoeBob »
You might need to use a very thin wire to clean out the main jet. I have had to do that after multiple carb soaks for the very same symptoms you list.
Could also be emulsion tube.
evilone
Post by evilone »
My modified 87 elite was doing that, I up-jetted, smooth all the way from idle to top speed.
