need help fast: How to Press the Bearings back into the case
cf_z
Post by cf_z »
ive been waiting for over 2 weeks for this new bearing and i thought i had it all figured out. I thought youd just get the crank set into the cases and start threading the bolts in and it would just press it self together.
Well i am having super problems with it. I cant seem to get it to tap more than about 1/64" into each side of the case. And i am afraid if i try to thread it together like i thought then i will just strip the case.
I sanded each slot on the case smooth with 360 sand paper so there are no nicks or burrs. I also used some GN2 to help them slide easier. i dont wanna wreck anything, and i cant figure it out!
HOW DO YOU PUT THIS BACK TOGETHER??
94 Elite SR.
PoliniCorsa+PGlong+28oko+8.44.1+KeliVariator+HiEnergyCoil+Pirrelis
=fast
cf_z
Post by cf_z »
okay i figured out that i was supposed to press the bearings into the case first. got that done.
but now that the crank is in the case, if i tighten the 4 bolts around the bearing that hold the 2 halfs together more than finger tight the crank becomes almost impossible to spin.
whatd i do wrong.
94 Elite SR.
=fast
cf_z
Post by cf_z »
nevermind. im an idiot and need to slow down :)
94 Elite SR.
=fast
chevyguyjay
Post by chevyguyjay »
lol :lol:
~2004 Geely Fashion~
patrickthenomad
Re: need help fast: How to Press the Bearings back into the case
Post by patrickthenomad »
What did you do wrong, why would it not turn? I'm about to do this to my spree and I'm pretty nervous. One of the bearings is stuck on the crank, should I try to remove it so that I can press it into the case? Back to the search function...
1987 Spree
2005 Honda Metropolitan
2008 Yamaha C3
