i only get 25 miles on 1 tank of gas
andy
Post by andy »
what i only get 25 miles on a tank of gass i know its 50 mpg but still this thing is small how do i get more :?: :?: please help :!: :!:
spreeman
Post by spreeman »
it does get 50 mpg, unfourtunately... the tank is only a half gallon or so :P
ferchja
Post by ferchja »
Maybe running a bit rich, otherwise it is within range.
Jeremy Ferch
1985 Spree (NQ50) - Mid restoration
1) Check that your airfilter and exhaust are clean. Check carbon on head and get a clean plug.
2) Check your main jet, should be #65
3) Check your needle jet position, should be at nominal (which is the forth position from the top.)
I get this question a lot, this is going in tech docs. You should be getting close to 50 miles per tank. That's closer to 100 MPG.
maddog
Post by maddog »
Well i only get 28 mi. to the tank but its a stroker and well worth it.
