Top Speed 27mph
jroyse
Top Speed 27mph
Post by jroyse »
i have an 1987 Elite 50, no mods. I can only get it up to 27mph. Down hill 29mph.
Did the factory put some kind of speed restriction on it?
gobucks
Post by gobucks »
check inside the head pipe of the exhaust, there should be a metal washer in there reducing the size of the pipe for a while, grind that out with a dremel, and if you take off the side cover on the bike and pull off the front vartiator/ crankshaft pulley there should be a plate on the back of the pulley which is held on by three bolts take the plate off and throw it away.
http://www.scootertherapy.com/Eliteclutchpage.html
jroyse
Post by jroyse »
I pulled that plate off, drove and no difference. Didnt mess with exhaust yet.
gobucks
Post by gobucks »
the whole point of pulling the plate off is that it will allow the two pulley halves to come closer together allowing the belt to ride up higher making the gear ratio to be better for high speeds.
maddog
Post by maddog »
next time own some real speed :cry:
ALOW1
Post by ALOW1 »
jroyse wrote:I pulled that plate off, drove and no difference. Didnt mess with exhaust yet.
Is the belt wore? If the belts wore that will slow you down.
Base4life
Post by Base4life »
you cant really do mods to an 87 elite. If you want to do good mods get a 94-01 elite.
01 Elite
in progress!
Post by Kenny_McCormic »
Base4life wrote:you cant really do mods to an 87 elite. If you want to do good mods get a 94-01 elite.
You can but parts are rare, pipes can be made, it accepts DIO gears with some supporting parts from the DIO, bore kits are still findable, rollers and variator(im pretty sure) are dio.
