non dio elite motors
PimpinSpree
i've been searching for a dio motor for a while and i just havn't been able to find one. So ive decided im going to swap in a non dio elite motor. It may not have the potential to go 80, but at least it will be a * of a lot better than my spree motor, since it will have a variator.
my question is which motor should i get out of a:
1987 SE50 Elite 50 S
or 1988 SB50 Elite 50
vt cycles lists aftermarket parts for the se50 but not the sb50, so im guessing i want the se50?????
PimpinSpree
- chevyguyjay
PimpinSpree
well i bid on the one on ebay. Im sick of waiting to find one. I know its kinda high priced being it doesn't come with the starter, carb, rear shock, or rear wheel. But since i have 3 spree starters, im wondering will they fit on this motor? Also can i use a spree carb and put a bigger main jet in? Do i need to get the shock or can i make a spree one work? What about the spree rear wheel?
nope same as a SE except the 85 has a 2 bolt intake manifold that flows better.Base4life wrote:Try putting a aero 85+ motor in there. They take the same parts as a dio am i right?
Yea but your stuck with a midgrade intake, you cant put a 4 bolt high flow on it. And that means your stuck with a close to stock carb unless you have tools to machine a new intake manifold.
