been
nightwolf1772
nightwolf1772
As long as it is running good and not bogging down the answer is maybe.
You may want to check your tires and inflate them to proper psi.
A new spark plug would not hurt. Check your air filter and make sure its clean and not falling apart. A new one would be better. Also change the gear oil back by the rear tire and put fresh oil in there as well.
nightwolf1772
