Electric Starter Help
cody_maasen
So I just got my spree running today. I drove it for about a mile when the belt slipped off the rear pulley and lodged itself between the pulley and the case. Well ever since this happened every time I go to start the thing the electic starter pinion jams and wont come back down. I have to remove the gear to get it set back in. When i try again the saem thing happens. Any ideas?
cody_maasen
cody_maasen
Check that the large geared outer half of the pulley is not bent. There should be no shimmy at all when you turn the crankshaft (do it with the ignition off and plug removed to reduce resistance. Even better, use a dial micrometer if you have acess to one. Worse yet, your crankshaft could have been bent when the belt came off. Hopefully its just the large gear if there is some offset!
Clive.
Clive.
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
PS
Check the pinion also to make sure the belt did not push in one of the thin cup-shaped housings at the side so that it pinches the spring.
Clive.
Clive.
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
