been
nightwolf1772
been
Post by nightwolf1772 »
I j
Post by Kenny_McCormic »
If it was left outside the cable is junk.
nightwolf1772
Al
Last edited by nightwolf1772 on Fri Mar 05, 2021 2:21 am, edited 2 times in total.
hondaman
Post by hondaman »
As long as it is running good and not bogging down the answer is maybe.
You may want to check your tires and inflate them to proper psi.
A new spark plug would not hurt. Check your air filter and make sure its clean and not falling apart. A new one would be better. Also change the gear oil back by the rear tire and put fresh oil in there as well.
nightwolf1772
were is the air filter located? My dad was the one who normally worked on it but I m wating to learn about all the stuff myself
hondaman
Post by hondaman »
Keep looking . You will find it. Hint-- its under a cover with a hose running to it.
Near the rear wheel.
nightwolf1772
alright
