Turning flasher unit not quite working....suggestions?
nelly
Post by nelly »
Spree is running well and everything is working except for the turning flashers. When I select a right or left turn, the turning lights will turn on, but not flash. I can hear the little unit under the seat click on, and in fact if I continuously tap it, the lights will flash.
Anything I can do to get them working or should I just look to eBay?
Thanks
Steve
Do you have both front and rear signals hooked up? Are bulbs in both working?
burnt_toast
Re: Turning flasher unit not quite working....suggestions?
Post by burnt_toast »
nelly wrote:Spree is running well and everything is working except for the turning flashers. When I select a right or left turn, the turning lights will turn on, but not flash. I can hear the little unit under the seat click on, and in fact if I continuously tap it, the lights will flash.
Thanks
Steve
I have had this exact problem. You just have to ride around and eventually the lights will start flashing. Keep tapping the relay and it should start working right eventually, thats what i did. :P
I remember someone went and bought an identical relay from autozone for like 5 bucks, so maybe try that.
projects galore :nerd:
nelly
Post by nelly »
I actually don't have the rear turning signals yet - waiting for a rack and lights to show up from eBay. Would that explain why they're not flashing? You need to have all the lights hooked up and working to complete some sort of circuit?
vette76
Post by vette76 »
it could be that way. i know on my 87 if they werent all hooked up they just would blink faster.
87' spree (SOLD
12' wrx
MySpree
Post by MySpree »
hmm are t5hose the stock lights that u have on your scooter?
nelly
Post by nelly »
Mine? Yes they are.
MySpree
Post by MySpree »
hmm well i dont know then maby a messed up blinker realay. some lights dont have enof wattage and do not pull enof power to blink i have had that problem with my coustom blinkers but i eventually settled on these
awate picture
nelly
Post by nelly »
Noiseguy.....you were right!!
My rear rack and flashers showed up today after work, plugged them in, and blink....blink.....blink. All four flash nicely.
Wicked!
Steve
vette76
Post by vette76 »
wiring must be different on the older ones then i guess.
87' spree (SOLD
12' wrx
burnt_toast
o yeh, that would explain it. didnt know you were missing the rear blinkers. complete circuit is necessecary for it to blink too.
