Turning flasher unit not quite working....suggestions?
Spree is running well and everything is working except for the turning flashers. When I select a right or left turn, the turning lights will turn on, but not flash. I can hear the little unit under the seat click on, and in fact if I continuously tap it, the lights will flash.
Anything I can do to get them working or should I just look to eBay?
Thanks
Steve
Thanks
Steve
Do you have both front and rear signals hooked up? Are bulbs in both working?
- burnt_toast
Re: Turning flasher unit not quite working....suggestions?
I have had this exact problem. You just have to ride around and eventually the lights will start flashing. Keep tapping the relay and it should start working right eventually, thats what i did.nelly wrote:Spree is running well and everything is working except for the turning flashers. When I select a right or left turn, the turning lights will turn on, but not flash. I can hear the little unit under the seat click on, and in fact if I continuously tap it, the lights will flash.
Thanks
Steve
I remember someone went and bought an identical relay from autozone for like 5 bucks, so maybe try that.
projects galore
- burnt_toast
