cylinder and head leaking
filthyfingers
Post by filthyfingers »
my dumbass bolted on one of the four bolts too tight and it broke, the screw broke right on the case. when i start it up i feel air shooting out next to were its missing the bolt. so question is can i put on more gaskets or even some metal to metal sealant stuff to keep the seal? right now im thinking the worst and its trashed.. btw its off a 2001 elite s. im all bummed out
losthope
Post by losthope »
you have to pull it apart and drill and tap it. get a new bolt and torq it properly
keithw
Post by keithw »
If you are lucky when you take it apart you can get the broken bit out and the threads on the case won't be buggered. The torque spec for these is like 7 ft/lbs, not a bunch. I use a 1/4" drive ratchet handle and can get them plenty tight.
keithw
Honda Spree, 1985.
Another Honda Pal
Post by Kenny_McCormic »
An experienced mechanic should be able to get it out for you.
gobucks
Post by gobucks »
if there is any of the bolt sticking out when you take the head off, then go to auto zone and rent a stud remover, this thing saved my butt by getting a head bolt out of a ford engine that i was doing the head gasket on.
1) Since the bolt was not seized in position, it will should take very little torque to remove. If there's a bit sticking out after you remove the cyl, cut a slot with a Dremel tool mounted up with a cutoff wheel. Align your cut tangent to the bore. That way if you slip or cut too deep (into the case) there will be no leak path past the gasket. Then just use a screwdriver.
Note: Putting a slot on the broken bolt will make it difficult to start the drill part of the drill/tap path. If the slot does not work see next idea
2) Consider checking with an experienced welder. They often can get broken bolts and studs out without thread damage.
filthyfingers
okay, i took it all apart and found out that it broke off right under the case so nothings sticking out :evil: . i'll try to drill it out and put a helicoil insert into it and that should hopefully be it. i'll try to get pictures just incase this happens to anyone else.
DorkoElite303
Post by DorkoElite303 »
....you could just put it on the sells forum. or put it on ebay and let all of us fight for it:-)
Drill and easy out.
