Need help with LX porting
Clivester
Post by Clivester »
I just bought a cheap large bore (63cc) cylinder for my Elite LX. Its not a great quality piece of work (did I say cheap!), but I got it thinking I could afford to play around with it a little to get used to the 50cc Elite.
The ports are poorly finished, so right now I am just cleaning them up by removing roughness from the casting and doing minimal airflow improvement. The problem I'm having is that the boost port holes are different sizes and shapes which I'm sure is a reflection of the quality of the cylinder. Consequently, I'm not sure what to aim for when cleaning them up.
I'm hoping one or more kind-hearted person has a decent quality Elite LX (pre-Dio engine, angled exhaust port) big bore cylinder laying around so they can take a picture or two of the boost port for me to use as a model.
Here are pics of the one I'm working on to give you an idea of what its like :roll:
Hopefully your pic or pics will be better than mine - I really need a more head-on view of the port from inside the cylinder.
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
Post by Kenny_McCormic »
Just remember, you odnt want your intake area perfectly smooth, if its too smooth the fuel will bead up on the walls and cause WORSE performance, rough surface keeps the fuel atomized but that looks too rough. You want rounded holes with a slight bevel so the rings wont catch. Keep in mind that porting without a supercomputer and a lab full of equipment is a "looks right to me" sort of thing.
Clivester
Post by Clivester »
Kenny_McCormic wrote:Just remember, you odnt want your intake area perfectly smooth, if its too smooth the fuel will bead up on the walls and cause WORSE performance, rough surface keeps the fuel atomized but that looks too rough. You want rounded holes with a slight bevel so the rings wont catch. Keep in mind that porting without a supercomputer and a lab full of equipment is a "looks right to me" sort of thing.
I'm familiar with all that. I'm keeping what I do smooth but unpolished. It's the shape and size of the boost port used on the LX I specifically need help with.
Clive.
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
I would look at the stock bore and scale it up as necessary.
Clivester
Post by Clivester »
Would if I could :lol:
I don't have a stock to compare it with, just 2 of the same big bores with shapes all over the place!
Clive.
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
Pick the smaller one and file it to match the larger.
Clivester
Post by Clivester »
Kenny_McCormic wrote:Pick the smaller one and file it to match the larger.
Well that was going to be my fallback option. Was really hoping for something more specific though.
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
Hmm, I suggest asking for pics of a stock boost port then.Make sure you port match the bore to the case.
DorkoElite303
Post by DorkoElite303 »
exhaust side....you want that to be polished up very nice. Mirror finish. That will keep the carbon from sticking and help the back pressure flow.
Clivester
Post by Clivester »
Anyone have details on size/shape of boost ports :?:
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
