Well i just got done cleanin the carb all out and i also had a little junk in the petcock,,,, It still willnt start, it was runnin great a few weeks ago and now it willnt start, and i do not know the reason.......
also when i pull off the main fuel line going to the carb,, should gas be steadily leaking out or no? because none comes out when i pull it off.
Thanks!!!
84 spree will not start
greenninja37
- BMX
New to the moped scene.
Proudly riding a White 84 Spree
There should be no fuel coming out when the engine is not turning over. That's how the vacuum petcock works. Now you need to pull off the other tube going to the petcock (goes from carb manifold to the lower connector on the petcock) and pull a vacuum on it. With suction on that tube you should get a good flow of gas. Also, make sure you have hooked up those 2 tubes correctly.
Clive.
Clive.
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
greenninja37
- BMX
