klotz oil
justinnielsen01
klotz oil
Post by justinnielsen01 »
any one run klotz oil ? im going to try it . i herd it smells like candy.
tru72
Post by tru72 »
if i could find that stuff i would use it..
it has one of the highest content of castor oil besides castor 927
good stuff!
Elite1998
Post by Elite1998 »
I run it in my snowmobile..good oil..smells really neat to
I wanted to put it in my elite but its almost $13 for a quart compared to 9ish for a liter of Ipone and I haven't had any problems with Ipone so I'll stick with it
Honda Elite SA50-S
Stock motor, 9:1 gears, Kelli High speed pulley=a top speed of ?? Maxed the speedo out if that counts..average 45 mph
average 85 mpg
Post by Kenny_McCormic »
tru72 wrote:if i could find that stuff i would use it..
good stuff!
Remind me again what castor is?
keithw
Post by keithw »
Castor oil, squeezed from the castor bean. It's the classic two stroke oil and used in some old motorcycle engine crank cases. One interesting property is that it gets thicker with heat so your oil pressure doesn't drop to nothing when your engine gets hot. Also keeps you regular if you injest it. Thw WWI airplanes used it. The pilots were constantly inhailing the fumes and had a real problem with being too regular, if you catch my drift. Drinking a lot of alcohol was supposed to help.
keithw
Honda Spree, 1985.
Another Honda Pal
evilone
Post by evilone »
Is it injector oil? I looked at the Klotz website and didn't see an injector oil.
keithw
Post by keithw »
I simply don't know about using it for injector oil. Hopefully someone has some experience with it.
keithw
Honda Spree, 1985.
Another Honda Pal
justinnielsen01
i got some today it smells sweet and it synthetic injector i know some one that got me it for 10 a quart
Back many year ago...
We used to use castor oil in model airplane racing. 60 - 70% nitromethane, 20% castor oil and methanol for the rest. I recall there was sometimes a varnishing problem on cyl walls. Never liked the smell of burnt castor oil myself!
Anyhow, I did a search and came up with a modelers link with info by a lubrication engineer about the merits of castor and synthetic oil. It supports synthetic burning cleaner.
http://www.go-cl.se/castor.html
tru72
Post by tru72 »
yeah maxima 927 castor is al i use on my bikes, on my stock ones that i use the injector i use silkolene comp
tempest
Post by tempest »
use klotz snomobile oil
its made for injectors
nparks
Post by nparks »
What about http://www.klotzlube.com/storeProdDetails.asp?pi=6?
I'm interested, but I don't know where to find it other than online and I don't want to pay for shipping for a quart to test it out.
Read the tech sheet that stuff is not for injection.
http://www.klotzlube.com/storeProdDetails.asp?pi=25 this is the only injector oil I could find on their site. Its a smokeless carbonless oil so it should work GREAT for our purposes.
