help needed
deathwish
help needed
Post by deathwish »
i've been reading around this forum and i found soom great ways to increase performance of my spree, i have opened up the intake already but im sorta stuck on what to do on the pully and on the head :(, can any one help?
vette76
Post by vette76 »
if u dont have the right tools then dont mess with the head. the pullet can be done with even a grinder. on the inner pulley just take a little off of the middle piece so the pulley halfs are a little closer. keep in mind that you will lose low end power.
87' spree (SOLD
12' wrx
MYSTERE1
Post by MYSTERE1 »
after you mod the pully you have to use washers to keep everything elined.
MySpree
Post by MySpree »
wit pully mod i think i missed this one and which pully the inner pully? 8O
deathwish
Post by deathwish »
will i need a smaller belt if i mod the pully?
MYSTERE1
Post by MYSTERE1 »
yah, about 1" smaller in diameter. with the stock belt you will have to push it to get it to move off the line. it just slips too much. but try it and see for your self.
darat
Post by darat »
can i put the varitor on the spree. i have a extra one because i got a complete kit when i order my high speed kit. i was J/W
vette76
Post by vette76 »
1st of all u should not need a new belt. the clutch is spring loaded to keep tension on the belt. the other thing is a variator will not fit the sprees crank. noiseguy and i have already talked aboout it and tried it and its not even close to fitting or lining up.sorry!
87' spree (SOLD
12' wrx
