making my own pipe today.
Corey
Post by Corey »
I found a old pocket bike expansion chamber. I am going to hack off the old
rusted out stock muffler an weld on the expansion chamber hope I dont lose any performance.
Corey
Post by Corey »
what do you guys think?
Corey
Post by Corey »
you think im going to have to carb adjusting? If so what just mixture screws or am i going to have to go up a jet size?
Elite1998
Post by Elite1998 »
Don't forget to up in jet size..you'll have to play around with different jetting sizes..find one that runs a hair too rich and back down by one or two.
As for where to start I couldn't tell you..I'm assuming it will depend on how the pipe is made. Just make sure it creates enough backpressure
Honda Elite SA50-S
Stock motor, 9:1 gears, Kelli High speed pulley=a top speed of ?? Maxed the speedo out if that counts..average 45 mph
average 85 mpg
Dac
Post by Dac »
what he said /\ /\ /\ /\
let us know on how well it works.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
Corey
Post by Corey »
NO GOOD! that pipe is pure crap! It barley goes 20 now. Im guessing its not enough back pressure. think if i make a restrictive muffler it will fix it or should i just start over?
Dac
Post by Dac »
yeah, most expansion pipes have a little silencer on the end. Take like a 3 hp briggs tail pipe and weld that on the end.
im not sure ow much it will help, but it might.
Corey
Post by Corey »
what do you guys think about super trap exhaust?
http://www.heeters.com/ScooterPerformance.shtml
Dac
Post by Dac »
never heard of it. :?
Corey
Post by Corey »
lot of atv guys use em they also make a bolt on for a rukus.
http://webhosting.web.com/imagelib/site ... lx_piceh4m
burnt_toast
Post by burnt_toast »
ruckus is 4stroke..
that expansion chamber is way too small on that custom pipe. and yeah too free flowing i bet. capping it off should help though, and adding a smaller exit hole
projects galore :nerd:
Corey
Post by Corey »
so your saying that a fatter pipe is what i need? i stuffed a piece of rubber vacuum hose and it did help but only a little.
Corey
Post by Corey »
yes ruckus is 4 stroke but super trap also makes a different core for 2 strokes.
keithw
Post by keithw »
Go to the pipe calculator in the advanced tech section. Run the numbers and see how your pipe compares.
keithw
Honda Spree, 1985.
Another Honda Pal
darat
Post by darat »
ya i did the whole pocket rocket bike pipe and it sucked so d*** bad untill i put a washer in the pipe to slow down the flow
