K&N on a se50???
PimpinSpree
K&N on a se50???
Post by PimpinSpree »
do people have any trouble putting aftermarket air filters on se50s, are are they picky like the spree?????
chevyguyjay
Post by chevyguyjay »
ive got one on my aero, and one on my buddys spree with the aero engine. its all about jetting. putting one on a spree engine......good luck, you will need it. :wink:
~2004 Geely Fashion~
PimpinSpree
what size jet did you need?
chevyguyjay
depending on what mods u did, i have a 90 in mine. my buddy has a 95 in his. :wink:
PimpinSpree
so your saying right now i probably need a 90, and after the big bore id need a 95???
oh and yes kenny, i will "do plenty of plug chops"
Towlieee
Post by Towlieee »
Btw I'd recommend a UNI or other quality foam filter over a K&N
K&N's don't filter hardly any dirt, they just flow tons of air
Although its not so important on the street, as it is on a off-road vehicle, with how low the intake is on these bikes, I'd definitely run a foam filter
chevyguyjay
u want better flow. as long as u keep the filter oiled, it will do its job in catching the dirt, but thats my opinion. :wink:
chevyguyjay
oh, to answer your question.....every engine is different. plan on pulling your carb off a dozen times till u find the jet that works best for your engine. yes.....plug chops are necessary..........lots of chops lol. :wink:
PimpinSpree
ya, but it should be fairly close, i just want a starting point in the tuning process
my mods will be, drilled exhaust, k&n filter and 65cc contessa big bore
think 95 if you had to guess?
chevyguyjay
in my opinion, id start around 80 and go from there. i mean u can try a 95 right off the get go. make sure u check that plug color. hate to here u burned up your engine. :wink:
PimpinSpree
thats why i want to start high and work my way down. But from the info ive gathered, i think itll be around 90-95
