dio top end on 93 and back lower?
Corey
Post by Corey »
wont a dio top end bolt on the older lower end? there is diffrances in the intake port area right? so cant we grind and match the lower to match the upper?
Dac
Post by Dac »
i would assume with time on your side you could do it.
my only concern would be the crank, the 93 and under SA50s have a 40mm bore, where the 94+ only have a 39mm bore, yet there both 49.9 cc.
The bore and the crank determine the cc, so if the cylinders are different, but they are both 49cc, then logic tells us that the crank is different.
do some research before you attempt anything.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
Clivester
Post by Clivester »
Also the pre-94 SA50s have a 10mm piston pin while the Dios are 12mm.
Clive.
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
Corey
Post by Corey »
so i would need a custom piston. if the bore in smaller on the dio than the stroke must be longer.
Post by Kenny_McCormic »
its not worth it
losthope
Post by losthope »
Corey wrote:so i would need a custom piston. if the bore in smaller on the dio than the stroke must be longer.
even then compression would be lower and port timing would be off
