The Stroka....
DorkoElite303
The Stroka....
Post by DorkoElite303 »
So I've bee reading around and reading comments.
I want to know which would be a good stroker kit to go with for my 2000 HOnda Elite S? Mini Stroker? Full Stroker?
I know I want to do a H20 kit.
I don't want to worry about having a crack case later on down the line.
Any advice?
Dac
Post by Dac »
where do you live?
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
DorkoElite303
Colorado..maybe 15 mins from Denver.
Dac
Post by Dac »
its kinda hard to build a h2o set up here on the mainland, if you where in hawaii then its another story, but these full strokers and what not, they require you to mill down the inside of teh cassing, its not just a slap together thing like everyone thinks.
DorkoElite303
Oh Yes I know. I'm also wondering about advise on if I should strength the case by like.... glass pinging it? Or maybe do some bracket weldding.
I want to know if I go with the full stroker, will the case going to break right away or not.
Or So should I got with mini stroker?
tru72
Post by tru72 »
pm me, i can help you with some ideas if your serious...
Dac
Post by Dac »
i would do that /\ /\ /\
Tru72 knows everything you could possibly need to know, and he would be able to get the parts for you too. (assuming)
I have not heard to much about dio cases breaking open, i have heard of one or two, but nothing compared to how many strokers there really are.
maddog
Post by maddog »
The problem with full stroker kits is they don't make the round cylinder anymore which can handle the heat unless you go LC, the largest mini stroker is 44.7mm=76cc and no case mods needed, you can also go with a polini fabrezi 82cc crank/ piston kit with minor case mods but its all aluminium and doesn't last long, yes i have all of these engines :lol:
DorkoElite303
What was your top speed with your mini stroker??? Was it even worth it?
