Finally done painting! pics
starsnbars
Post by starsnbars »
I posted a thread showing how I made a painting template I think it's in the adv tech docs page now, but I finally got done painting it. The engine is still being worked on so the back wheel is just resting between the panels to get an idea of how everything would look. I still need to give everything a good polishing, my dirty finger prints are all over the place.
Post by Kenny_McCormic »
looks alright.
mopedman
Post by mopedman »
i like it
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
chevyguyjay
Post by chevyguyjay »
its different for sure. not bad. 8)
~2004 Geely Fashion~
e_kmiec23
Post by e_kmiec23 »
I like it as well!
Eddie Kmiec
junkyspree
Post by junkyspree »
I like it, only thing is that white paint shows dirt and grease or any little imperfection quite easily. I like the two-tone vespa kind-a-look!
Elite1998
Post by Elite1998 »
Not bad..as "Junkyspree" wrote, the white will more that likely show more than you want it to so you'll always be cleaning it..I would have went silver or black just because of that. I really like the paint scheme nonetheless though
Honda Elite SA50-S
Stock motor, 9:1 gears, Kelli High speed pulley=a top speed of ?? Maxed the speedo out if that counts..average 45 mph
average 85 mpg
GIJoeBob
Post by GIJoeBob »
You need a white seat with blue piping.
EvilCrayon
Post by EvilCrayon »
Anybody else think BMW?
I love white wheels though. Just painted my red spree's wheels white. Looks JDM!
e_kmiec23
Post by e_kmiec23 »
Now that you say something.... yeah I see it too! :D
Eddie Kmiec
Miller1155
Post by Miller1155 »
Looks good!!
Tonight.... we ride!! TKS rule!!
PimpinSpree
Post by PimpinSpree »
i hadn't thought of somthing like that. I was gonna make a thread about what color i should paint my spree. Im now deffinitly thinking im gonna paint a two tone scheme. Maybe not that exactly, but maybe somthing similar
Looks very Mariner. I like the engineless look as well :D
I see you found a good use for your Complete Guide to Needlework.
Admin, Hondaspree.net
TAG
Post by TAG »
That's a very nice paint job! What kind of paint did you use? What did you do to prep the surface before painting?
starsnbars
I used Rustoleum spray paint for plastics. It was cheap and very easy to use. Before painting I wet sanded all the plastics with 400-600 grit. Then primed, base coat, clear coat. Also recommend using a rubbing compound after its all finished. One problem I did run in to was painting the front shield because it was the only piece that needed paint on both sides. I also had to repaint a few times because I didn't sand very well in a few areas and the paint started to flake off where the original clearcoat wasn't sanded through.
