What is the Final Drive?
We are dealing with single digit HP numbers, nothing is gonna break, more parts means it will wear slower.mikehelms wrote:More gears, more potential repair costs.Kenny_McCormic wrote:spree trans is a2 gear, elite is a 3 shaft 4 gear setup.
-- Mike
'86 Honda Spree
'05 Ducati Monster S2R
Not really. More gears increases frictional losses in the driveline, and creates more points of failure. Doesn't matter whether you're pushing two horsepower or two hundred ... the principle is the same.Kenny_McCormic wrote:We are dealing with single digit HP numbers, nothing is gonna break, more parts means it will wear slower.
I'm not saying that it's a bad design ... but if, for instance, the problem was either a lack of oil or a decline in oil quality that caused this problem, then the three gear rear end will almost certainly cost more to repair than the two gear rear end. And a three gear rear end *will* take more work to rebuild.
I'm still working on the idea of a rear end rebuild costing $500 - and the more complicated rear end makes that a lot more plausible.
-- Mike
'86 Honda Spree
Its a 2 hour job, unbolt belt cover, remove clutch assembly, remove muffler, remove rear wheel, unbolt cover, remove the gears and replace whatever parts need replacing. They want you to buy a new one.
PimpinSpree
