no start / no spark
no start / no spark
First of all my battery is crap and I don't want to buy one right now. I just kick start it. I know the electric start works since I can jump the elite from good battery. Today I have no start, I tried to jump it and use electric start...nothing. I checked spark at plug using kick start and nothing. My question is...would whatever controls electric start cause no spark? I doubt it but you never know. What service manual should I look at for diagnosing? 1988-1993 sa50 or 1988-2002 sa50? I have the 87 elite se50.
The starter circuit - relay, wiring are independent from the ignition.
Only common point is the ignition switch. But even then the contacts are different. When the IGN is in the OFF position a separate set of contacts are closed to shut off the spark.
Try running the resistance checks for coil, cdi and stator.
