Awesome Speed & Shut Off
- BMX
So today, I was riding my spree just like normal at 25mph, because my engine has been acting weird, on a flat road. I wanted to pass by a biker so I gave a little gas to see if I would accelerate past the biker faster. After I had passed the biker, I looked down to see that I was going 28mph. I gave it a bit more gas because I had never seen it go this fast ever since the oil went low and I couldnt' get a hold of any till 2 days later.
Anyway, I was going 28mph and then I slowly went to WOT. At WOT, it sounded beautiful and I went to 35mph and then 40mph. After about 10seconds of 40mph+ speed, it suddenly gave a pop, fire shot out my exhaust and then my engine lost power like the gas was giving out. I had a 3/4 tank so it shouldn't have been doing that. I was giving it WOT and trying to rev it but it would only accelerate in small bursts and the gaps between those got longer and longer until half a block later, my engine shut off and I pulled over.
I couldn't get the engine to start again and then I called my friend and he said he had the same problem before and that sucking on the vacuum line to the petcock should get it to start again. I did this for 15 seconds and started it. It ran normal again, maybe a bit nicer actually, but it was running normal in 2 minutes again, not getting past 25mph.
It did this 3 times over the course of the day but I just cranked it for a good 5 seconds straight and it would start right up.
Anybody know if my petcock is broken or something?
- BMX
- BMX
- BMX
kenny, are you mad because someone has a faster spree then you???
honestly dude, do another plug chop. if your plugs are coming out the right color, and you are able to pull 40mph everywhere, i got to say, that's going to be the first i have heard of this.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
- BMX
Man I am not an expert on engines but it does not sound healthy what you are doing!
Does it have a stock standard exhaust? An expansion chamber would cause a powerband kick in at a certain amount of revs I imagine, also has there ever been any work done on your engine e.g. cylinder rebore and larger piston?
I read somewhere on this forum that running a '85 piston in an '84 spree will give you more power?
Trust me you don't want to seize it, I did that and it's costly to repair!
- BMX
Besides drilling out one baffle in my exhaust, it's stock.
I want to rebuild the engine soon just because it's never been looked at and there's probably tons of carbon inside. Anybody know of a guide?
Something tells me it's the petcock cause it's been slowly getting worse. The beginning of summer, it was getting 31mph, and then 27, and then 25, 28-29mph again, and now it's at 25mph.
Well if I ever buy a spree, one of the first things I will do is pull off the top end just to check the condition of it. That would then give me a good idea as to how badly I can treat it. It's probably a good idea to do that I guess, provided you know what you're doing. Maybe there is such a huge buildup of carbon that you are getting more compression from that haha
- BMX
