Need Help===Removing Alternator Rotor on Chinese 49.9 Scoot
islandbayy
Post by islandbayy »
Hello, I am in need of removing the Alternator Rotor to replace a customers damaged stator.
It's a long story, but to keep it simple, customer decided to clean fan, put wrong bolt back to hold it on that was longer then stock, and that longer bolt chewed up the stator.
Anywho, I removed the nut holding the Alternator Rotor on, and expected the rotor to pop right off. Well, wrong :(
I could use some tips to remove the rotor without causing damage. I tried a gear puller, but did not tighten it very much so I would not cause any damage, or heaven forbid, crack the aluminum.
With all the hundreds of Chinese Scoots I've sold, this is my first time needing to replace a rotor, and having a really tough time finding documentation on the setup.
Ideas would be awesome. Sorry, no picture of the setup, I let a family member borrow my camera Friday, and have not had a chance to get it back :(
THANKS!
http://KmanScooters.com
http://MilwaukeeEV.com
Take a look at your flywheel just outside the nut on the crankshaft, chances are it has a left hand external thread. There are fairly standard pullers that thread into this, then screw down a bolt, that pushes on the crankshaft.
Here's a thread discussion methods of flywheel removal.
http://www.hondaspree.net/phpBB2/viewto ... eel+puller
For Hondas, folks here have also used steering wheel pullers, using the 2 bolts that hold the fan on. Same as your customer found out, you've got to be careful with the bolts, to avoid stator damage. But since you are a business, I'd recommend the proper puller, they are not very expensive.
