WOT sound: NEE NEE NEE NEE -- 2001 Elite SR
bryanska
Post by bryanska »
Hi - when I am cruising wide open on flat ground (35 MPH) I hear/feel an oscillation in the scooter. The motor kinda goes "NEE NEE NEE NEE" very subtly, as if I'm bouncing off a rev limiter.
It's not a hard bounce, and no power is lost. Mostly a difference in sound.
Normal? Not normal?
2001 Elite 50SR (SA50 I think)
2100 miles
Totally stock
Never de-carbon'd pipes or manifold
New NGK plug
Very slightly out-of-true front wheel after a crash (replaced front fork)
The more I learn, the less I know.
burnt_toast
Post by burnt_toast »
may have something to do with it.
otherwise if no power lost, I wouldn't worry about it. 35mph is right speed for stock S
projects galore :nerd:
Post by Kenny_McCormic »
Plug chop
Don't all 2-strokes do that at WOT?
noiseguy wrote:Don't all 2-strokes do that at WOT?
Not when tuned correctly. Should scream right along real smooth.
SpyderMike
Post by SpyderMike »
mine did that, then i cleaned the carb and now the "bounce" is gone
SpyderMike
and my main jet was backed out 1.5-2 turns, so it was tight when i put it back together
dont know if that had anything to do w/ the noise, but that was the only problem i seen
wilsoniya
Post by wilsoniya »
Is your plug properly gapped? My scoot cuts out at high RPMs unless I have a very tiny gap.. like 0.7mm or less.
2001 Elite S (SA50P)
- Nickname: "Black Magic" or "iPed"
- Derestricted
- OKO Hi-Speed Variator (9g rollers)
- 9:1 AM gears
- ~45 mph (on a good day :)
EliteS120ccJDM
Post by EliteS120ccJDM »
Probably the C.D.I ... change it to a racing C.D.I box..that's what I did..it takes of the rev limiter...so at top speed you won't hear that...and it throws more spark...so you'll probably top out at 36 or 37mph
Dac
Post by Dac »
EliteS120ccJDM wrote:Probably the C.D.I ... change it to a racing C.D.I box..that's what I did..it takes of the rev limiter...so at top speed you won't hear that...and it throws more spark...so you'll probably top out at 36 or 37mph
your nuts. the stock CDI isnt rev limited at all. And the stock spark is already blue/white, you cant throw more spark.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
