1985 spree
hondaken
1985 spree
Post by hondaken »
Is there anything that I can do to make it go faster without buying parts?
Short answer, NO!
Have you read through Adv Tech Docs? Spree can be sped up with a file and some time, but you need to read up first.
needfasterthan31
Post by needfasterthan31 »
take the airscrew completely out.it will do 40 miles per hour then youll seize the piston and scratch the cylinder up.
01 Elite SR50
>Polini Contesta 72cc Kit (To be soon installed)
>R1 Pipe (To be soon installed)
>Keli Variator
>9:1 gears
Post by Kenny_McCormic »
There arent any "parts" for it.
Kenny_McCormic wrote:There arent any "parts" for it.
Didn't I say that in the second post in this thread?
He said without buying parts.
OP: You can make a spree hit 40 with $100, a welder, and a dremel. But I doubt you can handle it.
hondaken
Post by hondaken »
OP: You can make a spree hit 40 with $100, a welder, and a dremel. But I doubt you can handle it.[/quote]
Hows that?
Port it out
build an ex chamber pipe
get head milled
get pulley milled
hondaken
Post by hondaken »
Too much work, plus I don't want to give up low end power. I did file the intake tube some, I think I'll file some more, that didn't seem to help much. thanks for the info though.
evilone
Post by evilone »
Just curious what you mean "intake tube". Are you talking about the intake port? :?:
You wouldn't lose any bottom end from stock configuration. Intake tube is the pipe between the carb and engine.
needfasterthan31
only drive down big hills and lean forward.
01 Elite SR50
>Keli Variator
>9:1 gears
hondaken
Post by hondaken »
needfasterthan31 wrote:only drive down big hills and lean forward.
lol yea, I'v hit 45 thatway, that was a fun hill
devenex
Post by devenex »
lose weight :lol:
1986 Spree w/ '87 SE50 motor
