Tools
EvilCrayon
Tools
Post by EvilCrayon »
So I want to work on my scooter and after moving out, I didn't have my dad's tools. I left my job at the auto shop so no tools there. And now my friend has moved and I used to use his tools.
To work on my scooter, specifically rebuilding the engine, what would I need?
Post by Kenny_McCormic »
1/4" drive torque wrench
full metric socket set in 1/4"
some larger metric sockets in 3/8 drive
1/4 drive ratchet
3/8 drive ratchet+ some larger sockets for it
extensions in both drives
strap wrench for pulling the front and rear pulleys or an impact gun and everything that goes with that.
bradthreee
Post by bradthreee »
Ratchet, 10mm and 8mm sockets, flywheel puller 21mm RH thread, flat head screwdriver, and as for pulling the cases apart I don't know what special tool is used for that.
You can buy a tool kit @ sears for $99 or less and won't come with the flywheel puller but it is a good entry level multipurpose tool kit
Dac
Post by Dac »
Ratchet, 10mm and 8mm sockets will take you a long way on this bike.
When you say rebuilding you are being very vag. making it hard for us to help you. Do you mean like swapping cranks? or just replacing the cylinder? Trans work? gears?
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
Chisholm
Post by Chisholm »
You are being very vaginal.
If you do decide to get a tool kit, I advise getting a metric only one. The sae sizes are really only good for working on houses.
I'd just buy some cheap Odd Lots or similar tools especially for your smaller sizes.[/quote]
veedubh20
Post by veedubh20 »
crank case split tool must need!
bradthreee
veedubh20 wrote:crank case split tool must need!
Where does one aquire this tool?
evilone
Post by evilone »
Or use air hammer with flat-faced bit and work your way around loosening it.
Chisholm wrote: I'd just buy some cheap Odd Lots or similar tools especially for your smaller sizes.
I don't agree on this. Minimum level of quality should be Craftsman (in US) or equivalent. Cheap tools will break as much as they fix.
buy craftsman or if if your rich, snap on. Both are guaranteed forever, like a zippo.
evilone
Post by evilone »
guaranteed forever unless air power, then it's 1 maybe 2 year guarantee.
We are talking about hand tools.
Johnny5
Post by Johnny5 »
A good quality Beer. Cheap Beer always breaks stuff.
evilone
Post by evilone »
just something to know in case you want air power and go to replace broken tool and they say "no".
