On other bikes I've seen reports of people epoxying the bystarter needle and barrel into the carb then adding a "priming bulb" to use as a starting aid. Kind of like the ones on chain saws. An extra port has to be drilled into the manifold to squirt in the fuel.
It helps start the bike but typically it still runs like c**p until it warms up.
Check out this site for parts to play with!
http://www.mfgsupply.com/SnowCarbPrimer.html
Clive.
I Hate My Bystarter
Thanks for that link, Clive. Though slightly inelegant, something like that would suit me fine.Clivester wrote:On other bikes I've seen reports of people epoxying the bystarter needle and barrel into the carb then adding a "priming bulb" to use as a starting aid. Kind of like the ones on chain saws. An extra port has to be drilled into the manifold to squirt in the fuel.
Clive.
At what position on the manifold should the 'squirt port' be drilled?
CaptDan
Hi Dan:
check out this link for a description of doing the mod on a 4 stroke GY6
http://www.rc-trucks.org/gy6-engine-performance.htm
They actually put the "squirt" inlet into the bystarter hole after the bystarter mount is removed. Not sure this would work for the Spree carb though, because its more integral to the carb body.
I don't think location of a "squirt port" in the manifold would be too critical, although proximal to the carb would be preferred.
By the way, Dan, I currently have my SB50 in pieces doing painting and tranny work. I think the bystarter is the same as on the Spree. If we can figure a way to get it to you, maybe you would like to loan it to try on your bike to test your "2 bad bystarters" theory. If it solves your problems, at least you will have confirmed its the real issue.
Clive.
Clive.
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
Yeah, somehow I think doing away with the bystarter unit entirely would be detrimental to the carb's operation. Gauging by the excellent way 'Pasquale' is running (not starting), it seems to me, having that port plugged up good and tight is what the engine prefers.Clivester wrote:Hi Dan:
Clive.
I'd be interested in trying out your BS-tarter. Shoot me an email with your number and maybe I can come out to your digs and borrow it. (I promise to return it or you can send the police.
Thanks!
CaptDan
You can machine up a manual bystarter enrichment plug. I've seen those.
You can also fill the bystarter port with wax (don't use epoxy, it's not reversible) and plumb in a choke plate. I've seen that too.
You could buy a carb with a choke plate. Also seen that.
Lots of options. Personally I'd just test and fix what you have.
Admin, Hondaspree.net
I agree, but factory-correct BS-tarters are hard to come by. It seems the only ones available are aftermarket units of unknown operational merit.noiseguy wrote:You can machine up a manual bystarter enrichment plug. I've seen those.
Adding injury to insult, no two BS-tarters are created equal; some are longer, others shorter. Then there's the resistance issue.
In the meantime, I just invested in a $3 'choke.' It's a small Craftsman screwdriver that fits neatly in the 'paper clip' under the seat. Each day when I start the bike, I remove the 'choke' from its clip, work the mixture screw, and fire up the motor.
It's nice to know the temporary 'solution' is neatly tucked beneath my rear.
CaptDan
Looks like someone has tapped out the bystarter port and done a manual bystarter conversion.vinnie wrote:Here's some pics of my manual choke carby - maybe it's not a spree (or nifty fifty) carby cause I tried to stick it onto my working spree to get it going without a bystarter and the air inlet and fuel/air outlets are smaller than on my bystarter carby.
On second thoughts, looks like the carb originally had a manual bystarter that was removed, then rigged up with the cable.
Clive.
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
