Impact Wrench
- BMX
Impact Wrench
I think I need to add one of these to my toolkit. Any benefit of air over electric? Any recommendations on brand or amount to spend. I dont need pro quality, but dont want cr@p. I've read getting the wheels off without one is a PITA.
1987 Honda Spree
Air tools are smaller, but require a compressor. Electric tools are usually larger and heavier. I have one of each, I prefer the air tool.
Admin, Hondaspree.net
- burnt_toast
CHEAPER THAN THAT! Electric impact $20 at harbor freight when on sale!Kenny_McCormic wrote:You can get a cheapo electric one at harbor freight for under $100, probably under $50, they work fine.
It's one i highly recommend for scooter tuning, works great. and as far as quality I've had mine for over 3 YEARS! if it breaks I would have no regrets and easily buy another one, plus you can get 1yr warranty for like extra $5, cant beat it man.
air impact is not recommend because easily strips threads.
Harbor freight impact link:
http://www.harborfreight.com/cpi/ctaf/d ... mber=92349
Buy it and thank me later
projects galore
Air or electric will strip threads if you're not careful. This is more a matter of what the gun is rated at. Both mine will run to 200 ft-lbs; I dial the air gun back to minimum for anything on the scoot and haven't had a problem yet.
If you mostly are working on smaller stuff, take a look at 3/8" butterfly style air impact wrenches. Around 75 to 100 ft/lbs max, the 3/8" drive will get you into sockets that fit smaller sized bolt heads. You can set the wrench to a lower approx torque than a 1/2 drive to protect the smaller fasteners. 3/8 gets the auto valve covers, oil & trans pan, timing belt cover etc.. plus the yard equipment and scooters. It was also great for installing 2 1/2" lag bolts when rebuilding our entry way stairs.
If that fits your type of work, you could cover both bases with a good quality 3/8 drive, and a lower cost 1/2.
- BMX
thanks toast
I picked up that impact wrench you recommended and it was on sale for $19.99. Darn good deal. considering it will probably only be used for the spree, it should be all that I need.
Its been a while since I've been to the local Harbor Freight. Man that place is fun. Even though some of the tools they sell look pretty cheap, they have everything and is a Man's man place to hang out.
I also got a two pairs of work gloves (1 leather, 1 canvas), 2 packs of shop rags, 1 package of small wire zip ties, 1 package of large ones, an assorted pack of shrink tube, 75' of poly rope, and probably something else i'm forgetting.
bill was $40
bill was $40
1987 Honda Spree
