Flooding out....PO job maybe?
Ok, so, I've taken my carb apart for the 10th time. Getting quite good at it. Now, my Spree seems to flooding out after a couple minutes of idling, or after a few seconds of throttling (whichever comes first). I was wondering if anybody knew how to check to see if the idle (pilot) jet is damaged. I'm going to be checking the bystarter operation tomorrow, but the guy who owned this before me said he cleaned the carb. I don't know if he was shy about jamming stuff through jets. I mean, it could either be my float (needle) valve, float level, bad bystarter, or a damaged idle jet, right? Anyhow, if anyone knows how to check the idle jet for proper operation, do tell. Thanks again, keep up the awesome work!
check your petcock to see if its not closing. A easy test is to pull off the gsa line , if gas flows from it, the petcock needs to be replaced or sometimes its just stuck. Get the vacuum line that goes to and and give it a good suck..sometimes that unlocks it if your lucky, dont blow air into it cause it can be damaged internally.
aloha
D
aloha
D
Try squirting either carb cleaner (spray can), brake cleaner or WD-40 thru all the passages to make sure they are clear. Soaking sometimes just doesn't clear them.dgsoles wrote:Alright, thanks guys. I'm soaking the carb in some cleaner right now, I'm going to give it one more good cleaning. If it still does this, I think I'll buy a new needle valve.
Oh, I will. Once it soaks for a couple of days, I'm going to blow it out with 120 psi. Then, maybe I'll soak it again for another day, and blow it out again. Then, I'll rinse with some more carb cleaner. Then, I'll check the float level (not that I can do much adjusting on these Sprees), and see if it works...if it still floods out, I'll replace the needle valve. If it still floods out.......well, I'll cross that bridge when I get there. Thank you guys for the help.
- minihondaclub
Make sure your float is not broken where it sits with the needle and that all the carb parts for the float bowl are there. I had a lot of issues with the previous owner who "cleaned the carb" himself. He broke parts and left some crucial ones off.
My flooding issue was a broken float and a missing screw for the float pin.
Good Luck and hope this helps. Check out the diagrams in the OEM parts that companies have for these scooters, they have helped me realize a lot of whats missing and where stuff actually goes.
http://www.powersportspro.com/pages/par ... Honda.aspx
High pressure air and carbs are a bad mix. The max pressure you should use is 35 PSI Carb manufactures include this info on rebuilds, why Honda didn't is a mystery to me. The high pressures can blown out pressed in parts and you will never know they are gone and then the carb will never work right.dgsoles wrote:Oh, I will. Once it soaks for a couple of days, I'm going to blow it out with 120 psi. Then, maybe I'll soak it again for another day, and blow it out again. Then, I'll rinse with some more carb cleaner. Then, I'll check the float level (not that I can do much adjusting on these Sprees), and see if it works...if it still floods out, I'll replace the needle valve. If it still floods out.......well, I'll cross that bridge when I get there. Thank you guys for the help.
