My bystarter is completely stuffed, all that's left is a little needle (pics attached)
I took that needle out because it was missingand running like crap, and after that it ran really well. I got told that it might be running lean and might seize again, so I put the needle back in. It runs pretty much the same as without the needle.
I did a plug chop, sort of. I run it at about half throttle for about 1 minutes, then cut the engine and pulled out the plug. Attached are the results. If the picture doesn't show enough, I'd call it very dry and slightly rust coloured.
Any help would be awesome. I'm really keen to start riding it without crapping myself if the engine misses haha! I had a look at the plug chop chart but it didn't tell me if I was running lean or not.
And is the plug chop guide from the mopedarmy site pretty accurate? Is it OK to run a spree WOT on the stand?
