Hey, I have a perfect exampe of a spree 50 with only 714 miles on it - it has been in a heated garage for over 23 years. HELP!
It was stored with fuel and oil in the tank, bad move on the old owners part - I've removed all lines and drained the tanks (oil and gas). I will replace the lines if needed. The airfilter literally crumbled in my hands. I ordered a new battery and some plugs already.
What else should I do to get it ready to run. I have not tried to start it and wont until its all ready to go.
lastly - will bigger tires fit on this ped?
I welcome all of your suggestions. Thanks!
1984-85 Spree - mothballed
THESILVERSURFER
THESILVERSURFER
thanks
thank you - im on it...any ideas on larger tires or other modifications? Should I replace the drive belt?
