Spree Won't Start
ARGHHHHHHH
d*** thing....been running excellent all week and then today I ran to McDonalds to grab a burger and shut it off, went inside and came back back out maybe 5 minutes later and NO START. So I walk home and get my truck pick it up. Check for spark; good! Plug looked perfect too, nice and brown. Just in case I changed the plug and still no start. Carb is all new and if I choke by hand a little gas runs out the intake side of the carb after a few seconds which tells me I am getting gas. Like I said, it was running perfect when I turned it off. PLEASE help, need to get the ole girl going again.
Thanks,
Eric
Thanks,
Eric
Bottom end leak? Reeds? Pull the sparkplug and the fan cover,spin the engine over by hand with ear next to plug hole, should hear a pop near bottom of stroke and have bottom end compression.
Anymore than 100 is acceptable though. I seem to have good bottom end compression as I distinctley hear a pop when I turn the fan. I guess I am going to pull the head this evening and see what she looks like. The reeds look perfect, clean and tight. They are opening like they are supposed to if I pull the intake and turn the engine over. Any other ideas???
Interesting statement, but my Honda manual flat out says "113 PSI MINIMUM". I don't believe 100 PSI is compatible with the factory manual.pre64 wrote:Anymore than 100 is acceptable though. I seem to have good bottom end compression as I distinctley hear a pop when I turn the fan. I guess I am going to pull the head this evening and see what she looks like. The reeds look perfect, clean and tight. They are opening like they are supposed to if I pull the intake and turn the engine over. Any other ideas???
pre64 wrote:The compression is okay...about 95 lbs per sq in. and this is with a gauge that uses the hose so it might even be a little higher than that.
So first your compression was 95, now its 101-102?pre64 wrote:About 101-102
Sounds to me like you need to re ring it.
Bear is right, if Honda says the minimum is 113 then it should be more then that. For how finicky these small motors are you should get it up to spec. That could be a good reason why you had it running but couldnt get it tuned properly so you took it to a shop. Its going to be real hard to tune a motor that has low compression.
You pull the jug (cylinder) and measure the diameter of the piston. Standard is 40.955mm to 40.970mm or 1.6124" to 1.6130 4mm from the bottom of the piston skirt.pre64 wrote:never been to a shop. I will figure this little scoot out. The reason for the different readings was a junk gauge. The problem with re ringing is I don't know what size rings to get. How can I meausure this?
Try pouring a tablespoon of oil down the plughole and then try to start it. If it suddenly runs like a raped ape after that till you shut down and let it cool down again it needs a rebuild.
pre64 wrote:Okay fellas, heres the story.
Had the spree running and but couldnt quite seem to get it tuned in just right. Took it a shop and waited and waited and finally got mad and went and picked it up. Now, she will not start!!! The carb is fresh as well as the by starter. If I unplug the bystarter and choke by hand it still will not start. I am getting good spark and if I choke by hand while cranking gas will run out the intake side of the carb after a few seconds. PLEASE HELP!!! Need to get my lil scoot going again.
Thanks!
Strange
