Aside from the vicious interpersonal attacks, here's what I've learned so far:
1. The NB50 Aeros built after 1985 had throttle-controlled oil pumps. The pump is geared to the crank, so it IS RPM-sensitive, as well as responding to increased lube demand occasioned by opening the throttle. The stock engines seemed to run indefinitely and trouble-free, for the most part, using Honda oil and pure gasoline in the tank.
2. A Polini 65cc bore kit (47mm piston and cylinder) ups the ante in terms of heat production and (perhaps) lubrication needs. The main jet included in the kit (a #80?) addresses the engine's mixture needs. The stock fan/shroud may or may not suffice. To compensate, many feel it is necessary to increase the supply of lubricating oil.
3. There are three ways to achieve that: A. Adjust the pump to maximum opening, B. Leave the pump alone, and pre-mix at a dilute (say, 50:1) ratio, or C. Defeat/plug the pump and run a straight 32:1 premix.
I just resurrected my Aero, which had sat untouched for 7 years. My old OMC outboards ran on 50:1 premix, so I decided it might be prudent to mix such a batch to re-"break in" my stock engine with a little "insurance". I put a few miles on it - with the pump connected. It smokes just a little - no vapor trail, but visible smoke out the exhaust at all times. I'm assuming the pump is still working. I believe this because otherwise I would not see this much smoke and probably would have had a problem by now using only 50:1 in this air-cooled application at South Texas temperatures.
This week I should be installing my Polini 65. I still have about a gallon of 50:1 in my fridge
Once I consume my current supply however, I would prefer to avoid the chore of pre-mixing. Some have indicated that they have adjusted their pumps to open sooner/wider with their bore kits. I would like to hear from them.
Specifically, how they set the pump to deliver the maximum - or at least sufficient - oil supply to provide a bit more lubrication than the stock "50cc" adjustment delivers.
