So i was turning the pully(?) by hand today as I was flushing the motor. I noticed that at some points in the cycle(piston going up and down), the crankshaft arm would get stuck. It looked like it was getting stuck at the bearing, right between the two plates that sit on each side of the bearing.
I noticed that if I backed it up the other way a little, it would loosen. Now, this didnt happen every cycle, just intermitenly. Could that be because there was no oil in the bearings due to the cleaner? Or could there be a problem with the entire camshaft bearing assembly?
I looked in the tech docs for some literature on how to remove and inspect them. I didn't see any.
Can I have a little advice/input on this before I re-assemble?
It seemed to be getting stuck right here in the yellow circles
Thanks!
