Im at a loss, and have no clue what to do
well now that i finally have spark it wont run . it has about 130 punds of compression has spark, but im going to try a new spark plug because i accidently ran it lean because the air filrter tube fell off and didnt know it so if the new spark plug doesnt work im lost. ive tryed everything starter fluid stil wont crank all it will do is act like its about to start and the stop, there is no leakaround carb and intake beacuse i have them really tight and silconeso i hopen its the spark and if its not i dont no what im going to do . any thing i mean anythingif i might be doing sumthing wrong just tell i im so l ost irght nowi have no clue .. thanks
- MYSTERE1
- Goped
just a thought and i'm not saying this will solve your problum but, is your battery fully charged? even if it is turning over try giving it a boost. my spree wont start unless i have a strong charge in the battery.
just a thought.
just a thought.
Mystere
1985 Honda Spree.
Front pully mod, 1" longer belt,
gutted pipe, K&N air filter, #80 main jet,
Intake mod, Leo Vince clutch springs,
40 MPH top speed.
1985 Honda Spree.
40 MPH top speed.
- burnt_toast
werd. jumping off a car does the trick for me.MYSTERE1 wrote:just a thought and i'm not saying this will solve your problum but, is your battery fully charged? even if it is turning over try giving it a boost. my spree wont start unless i have a strong charge in the battery.
just a thought.
projects galore
yeah that happens to me too.
anyway 130psi is too much. should be 114-116psi. sounds like u have carbon build up in the head. pull the exhaust off and check to make sure the port is not blocked.
87' spree (SOLD
12' wrx
87' spree (SOLD
12' wrx
it has a brand new piston and before tht i cleaned everything. it mgiht be the exhuast butit ran jsut a couple a days a go then slowly died over the next few days the battery is dead but it ran with out one. im goning to change the spark and then ill see if it works but if you ovber tighten the intake thing to the motor could that cause it now t crank?
Did you put the piston in yourself? Did you hone the bore, and then afterwards lightly sand the edges of the ports? Have you rechecked compression since it died? I'm wondering if you accidentally trashed your rings.
By the way, DO NOT USE SILICONE ON THE INTAKE TRACT! Silicone sealant is for water pumps, not bike engines. There are a few (very few) cases to use this around the oiling system sparingly. Silicone will end up in your oil pump if overused (not on Spree, for future reference) and can get sucked into the intake. I've actually got an intake/reed block that came from a dead engine with intake and reeds covered in silicone. I'm guessing that someone used silicone on the carb to intake interface and trashed the engine. Probably gets into the roller bearings. If you used it, take it back apart and get it out of there.
Admin, Hondaspree.net
Shouldn't be that high. Sounds like a plugged exhaust. Check tech docs for how to clean.
just pull off the exhaust and try it. (not late at night.lol.) if its works then u have a clogged muffler and u get the joy of cutting it apart and cleaning it.
87' spree (SOLD
12' wrx
87' spree (SOLD
12' wrx
