My Pal at full throttle when it gets into it's higher speed range and high rpm it starts to hesitate like it is lacking fuel any ideas before I start ripping it apart.
beefy wrote:Its running lean turn the air fuel mix screw on the carb to the left at least a quarter turn maybe more might have to adjust the Idle after that too
The screws are for idle only.
