Step 1: go out and buy these items. (Yeah, that's a huge pipe wrench)
Step 2: Wet sand down all the major scratches with 120 grit and 220 grit with black and decker mouse sander. Then sand at 440, 600 and 1000 grit by hand. Sand down every fricken panel wasting 8 hours of your day and cramping your hand like mad.
Step 3: Paint each panel with krylon fusions gloss black.
Step 4: Swear a lot realizing you are not a body shop kinda guy and hate this type of work. Realize that if you're not going to hand sand every fricken inch of the panel by hand to like 2000 grit, then you should have just sprayed it with the paint without sanding.
Step 5: Try out krylon untra flat black that has been in garage all winter at negative degree temps on front fender. Notice that even though it looks like crap because it was quasi frozen, it coveres all the areas that the krylon fusion did not. Try a half and half on front fender with ultra flat black and ultra flat black with clear on top.
What i'm wondering is this: Krylon fusion is suppose to be great for plastic, (NO PREP NEEDED MY *) but it seemed like it didn't want to stick to anything not super sanded. Could have been road gunk or tree sap, I dunno.......But the ultra flat black seemed to stick to anything (i've used this before on my crx and it stuck to EVERYTHING. Should you prime the plastic before painting?
I think i'm gunna go to the store and get a NEW can of ultra flat black and try painting a panel with that, then clear coat.
