lead is to toxic so hmmm
what could be used as a nice additive im thinking the properties of lead would make for higer compression and the like but whats every one thing would do simmilar
- burnt_toast
Adding lead to the gas(?) does not increase compression. Lead raises the octane rating of the gasoline allowing you to run higher compression. You get higher compression by shaving the head.
keithw
keithw
Honda Spree, 1985.
Another Honda Pal
Honda Spree, 1985.
Another Honda Pal
Fishing Weights
The octane-raising additive that used to be added to motor fuel was a chemically complex substance called Tetra-ethyl Lead.
You can read all about it here:
http://en.wikipedia.org/wiki/Tetra-ethyl_lead
Check this before you go dumping all your old fishing weights in the fuel tank, raise your compression to Diesel levels and blow up.
I will say that over time your tank will become nicely polished inside...
And your nether zones will be well-protected from ground radiation. Rethinking, maybe that's not such a good idea...
- steffen707
Survival of the fittest wheelman.
If you want to raise octane, just buy race gas. We have turbo blue in our area, guess what? Still has lead in it. Or you could check out touline and other addatives. IMO, not worth it at all unless you're doing some crazy race engine.
87 Honda Spree,
XX Yamaha YSR50
92 Yamaha Jog -> Stock.
05 Kymco Super 9-> My cruiser
XX Yamaha YSR50
- scooterwerx
