question for the experts
gsxrg
Post by gsxrg »
I have a great bike but would like to get some more power out of it.
I have a Arnada with the following mods
-72cc contessa bore
-7.9 to 1 gears
-24 carb
-ct crome mani
-typhoon pipe
-oil plug (pre mix at 32 to 1)
Here is the question. Would changing the bore from a contessa to a corsa make a difference?
I use the bike as my daily ride and planing to build a spare motor. I can just save the contessa for the spare.
Thanks in advance for any help.
geo
veedubh20
Post by veedubh20 »
well just buy pg long pipe,28mm carb and corsa bore. Yes it will make big difference!
typhoon pipe got good low and mid range, not top speed.
gsxrg
Post by gsxrg »
I ride to work every day to town so I am tring to keep the noise down. (running a air box) I was thinking of the bigger carb and bore, but kinda worried about a louder pipe. Would the pipe make a big difference?
Thanks again
veedubh20
Post by veedubh20 »
noise come from a big carb 28mm and make pipe very loud.
pg long is much better than typhoon pipe.
I ride everyday my mod elite w/ pg pipe. cops doesnt bother me at all or mess around.:lol:
if you dont like noisy pipe, just run your typhoon pipe.
no matter, when ever any mod parts changes , still need to tunes/carb,rollers and jets. all the times! :)
burnt_toast
Post by burnt_toast »
hey what kind of speeds are you seeing with that current setup? jw
projects galore :nerd:
Giant Sucking Sound From the Left
My LeoVinci pipe is tuned for midrange and is eerily quiet. In fact when I switched from the stock airbox to an open K&N filter, the noise from the left side became considerably more intense than that from the exhaust. I kind of like it, because I can control it with the throttle, but my neighbors may or may not agree. :oops:
gsxrg
Post by gsxrg »
Right now I am able to get to 60mph. (on a flat) it take a while though.
I was thinking of another pipe but worried of the noise.
veedubh20
Post by veedubh20 »
pg long plus 10mph more.
maddog
Post by maddog »
the contessa piston skirts are longer than the corsa so you can cut them, run 7: 1 gears, do a japan dio trans convertion= cheap speed :wink:
gsxrg
Post by gsxrg »
Thanks for all the info. It really helps.
Just waiting for the ok from the wife!!!!!!
burnt_toast
I would say try the PG Long and keep everything else on your list as is, rejet of course and you should see some good gains
post up how it goes!
gsxrg
Post by gsxrg »
Here is the update. Wife just bought me a corsa kit. Going to save the contessa for a spare. Still braking in the motor but aready feel a differance. The sound is deeper and revs up faster. Can't wait till I can top it out. Now I need to beg the wife for the pg pipe.
